I've looked through many threads on the forum trying to find something similar, without success, so here it goes (sorry for such a testament):
After a very hard 10.000kms+ on the 2024 Sahara Desert Challenge (11th) edition, with Morocco, Mauritania and Senegal hard tracks and trails, I had a very hard time to figure out and to solve a very bad issue on my '15 VDJ200...
It all began after the headlight washer started to work by itself, continuously, even with the car locked.
I was inside the Senegal to Mauritania border, end of the day and when I saw the headlight washer coming out of the bumper, with the car locked, I decided to remove the, thought to be, fuse from the fuse box on the engine bay, drivers side.
This ended the headlight washer problem but it also kept the engine from turning...
I guessed that the fuse would not be the one for the headlights washer so I put it back (the headlights started working by themselves again), but I was not capable of driving the car towards the exit of the border, the engine would not even turn and the car wouldn't start, no matter what.
A friend towed it out of the border...
At first I thought that the fuse might be misplaced, however it was not and it was (it still is...) OK.
Maybe we have some terminal out of place, let's check again but nothing... The car was not dead, only it didn't wanted to start the engine...
Every electrical system was working flawlessly, but the engine...
Looking at the START/STOP button, it turned green upon foot on the brake, so no malfunction here;
I noticed that the 4LO light was flashing and the engine light was on but had none on the gearbox position (P R N D S) so I think that the ECU didn't recognized the gearbox lever position, therefore inhibiting the engine from starting.
Moving the lever from P to R it did light up the reverse lights, but still no dashboard indication on position (pic for reference).
I have disassembled the entire fusebox in the middle of the desert (Mauritania) and put it back together, however I haven't found any issue, broken cable, broken connection, whatsoever... The car started the engine after that and everything worked fine, no 4LO flashing lights, no engine light ON, P R N D S lights perfectly normal and the car drove perfectly until I turned the engine off, 1000kms later...
The next day it was, again, malfunctioning, the engine wouldn't start, 4LO flashing and engine light ON...
Unplugged 4 white plugs (inside the fusebox), plugged them back and the engine started (normally, with the START/STOP button).
Travelled about 2000kms, stopped the engine and in the next day everything was normal...
Travelled the last 2000kms back home but somewhere in between, once stopped, the engine got back to not functioning, 4LO flashing, engine light ON, even after unplugging and re-plugging the 4 plugs on the fuse box...
Called for road assistance (was already in the south of Spain) but before they arrive and after waiting a few moments, the car went back to normal and the engine started, always with the START/STOP button...
Once home, went to a TOYOTA dealer, talked the technician through all that happened (took the fuse off, put it back, unplugged 4 plugs, put them back, etc., etc., etc.) but the guy didn't found nothing, the car is perfectly fine and it starts the engine like if nothing ever happened...
My biggest concern is, of course, the lack of confidence in driving the car because I don't know why this happened, if or when it will happen again and what should I look for, replace, whatever to fix this once and for all.
I bought and built the car for some OVERLANDING trips, it has a lot of money invested on it (OME BP-51, DAKAR ZERO's, ARB long range fuel tank, snorkel, drawers, fridge, compressor, ECOFLOW power source, microwave, BMW front seats, DONALDSON's airbox, 12.000lbs winch, rear wheel (custom) carrier, RTT, FOCAL and MOSCONI sound system, full Avery Dennison with PPF wrap, you name it, for giving up on this, plus selling the car with a known issue is not my deal, I would never be capable of passing my problems to others without their consent and knowledge so, please, try to help me out because I would really appreciate some advice, some ideas and some technical information. The problem looks like it is only inside the fuse box (never touched it again..) however I'm open to suggestions, testing and whatever you think would be positive for solving this issue.
