This has been answered a lot, including your previous post about this. Whether you need a ballast resistor or not depends only on what type of coil you have. It doesn't matter what kind of ignitor or distributor you have. If you remove the resistor from a coil that needs one, it may overheat and fail.
The purpose of a ballast resistor coil is to make cold starts more reliable (in conjunction with a resistor bypass wire). There is no significant down side to having one other than they can fail. If this doesn't appeal to you just buy a non ballast coil. The new ignition and coil will not increase the spark voltage and increasing the voltage over stock has no effect on the engine performance, but may give problems with insulation break down and reliability. The things that determine the spark voltage are the spark plug gap and the load on the engine.
