ECU replacement
Does anyone have any experience with flagship one ECUs? Engine Control Module | Powertrain Control Module | Auto Computer - https://www.fs1inc.com/engine-control-modules.html?model=822&year=129 I have a knock sensor code 0325 circuit one that continues despite changing the knock sensor out, was just going to replace the ECU. Just bought the truck so any advice is appreciated.
When asking for help, it is useful to state the year and model.
That said, it is extremely rare for an ECU in a 1991-1992 and 1994-1997 to be faulty. 1993 was a questionable year.
My advice to a new LC owner is to learn to diagnose instead of just throw parts at an issue, you'll loose your net worth in about a year otherwise. You have a free downloadable FSM (Factory Service Manual) at your disposal here on the site. It is very through and will give you procedures to test out the circuit where the knock sensors are concerned with a multi meter. If all that's new to you I suggest you become acquainted with it and consider it part of the experience of owning a 30 year old utility vehicle.
as stated earlier the ECU is not a cheap or common replacement, but there is a section of your engine wire harness that comes in CLOSE contact with a hot EGR pipe near the back of the engine between the valve cover and upper intake. As those wires slowly fail one by one it'll make an engine do some funky things.
