turbo8
Supporting Vendor
Update:
All the machined parts are in. Supplier messed up on the front support parts and installed the wrong key locking inserts (Thick walled M5 inserts were installed, M6 inserts were called out) . They are remaking them and should be done by the end of the week.
I'm a little surprised they didn't want them back to just fix the issue. I estimated about 40 hours of my time to fix all the inserts, so must be cheaper for them to remake the parts and install the correct inserts....
The ones with the wrong inserts can be fixed, by drilling out the inserts and installing the correct ones. If you want a $300 discount, I'll ship you the parts with the wrong inserts. You will have to drill them out and install the correct ones, which I'll supply. There will be 18 of them that need to be fixed. Otherwise the parts will probably end up in the recycling bin.
Front skid, power steering protector and transfer skid should be finished and shipped to me at the end of the week.
Other skids are 1 to 2 weeks out.
Also, what the skids were designed for, high speed impacts in the desert.
