Angelo1
- Thread starter
- #21
Great information! Another concern of mine using a Dynamat or other product in door panels is water penetration between the mat and metal. I’d like to see what the LX570 has in the door panels and how they installed it. I priced out front acoustic windows for about $1030 for the set, not including motors and actuators that might be necessary to support the heavier windows. Definitely not worth the cost.When it comes to reducing unwanted sound in a vehicle you have 2 types of sound you have to deal with. Vibration, and sound waves.
Vibration:
1. Dynamat dampens panel vibration by bonding a layer of butyl rubber to the panel that is vibrating. You only need ~50% coverage to dampen most panel vibration.
2. The foil backed butyl products (Dynamat Extreme, etc) use a foil and thicker butyl rubber to reduce temperatures that pass through the panel. Coverage is equal to the area you are protecting from heat.
3. Lead sheets do the same thing as Dynamat but with more weight. It adds mass to the panel that is vibrating thereby increasing the amount of energy required to vibrate that panel.
Waves:
1. To reduce sound that isn't vibrating the panel you need an insulation that will absorb soundwaves. Butyl rubber products are a poor performer of this function.
Traditionally in homes you would use fiberglass insulation, or rockwool, closed cell foam, traps, etc.Automotive environments are VERY different from the home environment. They both have different weather resistance, space and weight requirements.Mass Loaded Vinyl (MLV) is one of the best products to do this in the automotive environment. It's a sealed foam that doesn't absorb water. You have to use 100% coverage for it to block the maximum amount of sound waves. But joints that don't have a good overlap or seal will allow sound to bypass all your hard work. Remember A 1 dB change in a sound equates to about a 26% difference in sound energy and a 3db change in sound is equivalent to doubling sound energy.Good luck and keep us updated with your results!
As I continue to drive my 200 more and not the sound vault X7, the less I notice the noise. I was getting used to driving something that was whisper quiet. As far as ice cold door panels, I am going to install a remote start.
