Angelo1
Has anyone used Dynamat in the doors of the 200? This is going to be my next mod to help with temperature control on the door panels and lower the interior decibels.
Yeah, it is called getting Lexus LX.Has anyone used Dynamat in the doors of the 200? This is going to be my next mod to help with temperature control on the door panels and lower the interior decibels.
forum.ih8mud.com
I noticed the interior door panels get and stay pretty cold during winter and adding Dynamat extreme should really help improve that, also during the hot months. It’s not that expensive to do. I know the 100 series folks have noticed a big difference on noise and temperature control.Yeah, it is called getting Lexus LX.
Personally, i have NEVER gotten much in terms of decibel reduction from putting dynamat in doors with my previous cars. LC maybe different? (I doubt it). Dynamat may help with bass resonance etc from your door speakers.
I think that to get lower noise level inside, you need to dynamat the floor and wheel wells. Much more worth it if you’re gonna go down that road…but way more labor intensive and $$$$.
Acoustic glass would certainly help but not sure I’m want to spend that kinda coin just yet. Dynamat if anything will make the door sound more solid when closing and less thin.I don't think I've seen that done, and would be interesting.
I've done full dynamat in a couple of my previous cars as an audio junky. One of things I learned is that it may not be about how much dynamat you put in. Rather depends more on where the major noise contributors are and where it's applied. Not to say it won't make a difference, but the difference could be minimal if the louder surfaces aren't touched. Probably similar from an insulation perspective.
There's a couple things that come to mind that could be adopted from the LX.
1) Front to rear door gap seals
Sound Insulation LC200
forum.ih8mud.com
2) Acoustic front glass
This might be a major area to attack for the LC that would make a bigger difference. The LX gets acoustic glass. I'm pretty sure that could drop right into the LC. Perhaps invasive and expensive but an option.
To your question, I don't see anything wrong with adding dynamat to the doors. You'll have to try and tell us if it makes any difference. I think it's an easy enough project as the door cards come out reasonably easy.
LOL, I thought it was getting Michelins for the LX?Yeah, it is called getting Lexus LX.![]()
Yeah, I’m just going to give the Dynamat extreme a shot. The noise is fine with me, it’s more to reduce temperature on the door panels. I really noticed it when it’s been in the teens and 20’s. Takes a long time for the inside door panels to warm up.I'm pretty sure the acoustic glass is not just a straight drop in. It may also require that you replace the window regulators (or at least the rail where the glass attaches to the motor. Do-able, but a pretty big undertaking
forum.ih8mud.com
Well….double pane glass helps with temperature greatly!!Yeah, I’m just going to give the Dynamat extreme a shot. The noise is fine with me, it’s more to reduce temperature on the door panels. I really noticed it when it’s been in the teens and 20’s. Takes a long time for the inside door panels to warm up.
