jhynesrockmtn
I am working my way through my Sniper install on a 77 FJ40 that had been modified by folks prior to me. It was running a Weber 38 copy and also has a Crane XR700 optically triggered ignition. I have the basic fuel hose wiring done. I am using a Robb MC surge tank and external fuel pressure regulator.
This may not fit anyone's experience here, but my question is, I've read conflicting information on whether the XR700 is a CDI (most responses say no, it is basically a pertronix alternative to replace points). ChatGPT says it is
The Sniper instructions are very firm that the yellow wire that connects to the negative side of the coil not be used with a CD type ignition system. It will damage the ECU. So, can I use the conventional wiring with the XR700 or does it put out more power than the sniper can handle even if it isn't a CDI box?
I will be installing the hyperspark distributor at some point. I just want to get the thing running for now and the Holley instructions say to start with a non timing controlled setup.
