I'm putting together my parts list for my dual battery system, and I have a couple of quick questions about my dual battery setup I'm working on.
97 LX450. Battery #2 will be going in USPS battery tray (thanks Dan). Washer bottle has been reloacted (with minimal bloodshed).
What guage wire to use between batteries? I'll be running the surepower 1315-100 amp battery seperator. http://www.surepower.com/pdf/separatorinterconnect.pdf
With this setup, you do not have to alter any of the existing wiring on the primary battery. The seperator closes when the main battery is at 13.2 volts. It seperates below that voltage. Basically, you take a lead from your starting battery, a lead to your second battery, and a ground wire. You can also wire up a switch to manually combine both batteries (self jump). I guess their self jump feature on such a small seperator works by paralleling the batteries, and letting the good one dump some current into the weak one, rather than dumping all of the current to run the starter.(dont know exactly).
I'm debating on 4 gauge or 2 guage between the surepower seperator and the batteries. I'm going to install a 100 amp marine circuit breaker (since the seperator is 100 amp, and the alternator puts about 90 amps). These leads "should" not see more than the 100 amps.
I'll pull 2 gauge (+ and ground) to the rear of the truck to a bus block. That will be on a 150 amp(or larger) marine circuit breaker. Individual circuits will be fused appropriately off the bus block. If more capacity is needed, I can go with a larger fuse(in place of the breaker), or pull an additional circuit.
I'll pull a 4 gauge (+ and ground) to a bus block under the dash for accessories. That will be on a 50 or 100 amp breaker. Individual circuits will be fused appropriately from the bus block.
Grounds from battery 2 will be to the body and the engine block. Grounds from the feeds to the back will tie directly to the battery.
I'm using everstart maxx- 1N batteries (both top posts and side posts). They are made by exide, available from wally world. free 3 year replacement, prorated after that. 1000 CCA and 200 min reserve. I'd like to use the side posts for the surepower feeds, and the top posts for the existing wiring (on battery 1) and accessories (battery 2). I think the side posts should be able to handle that current (since they are used for connections on side post cars).
Crude schematic below.
Suggestions are greatly appreciated.
