- Joined
- Jul 1, 2010
- Threads
- 22
- Messages
- 178
- Thread starter
- #21
donut fj80 just used spacers did not cut lip. Tapage OME bushings for 2" and drop bracket 2" for 4" total lift.
saying OME bushings are for 2"of lift is being overly generous with what they will provide. I've only seen them work for the stock height heavy springs that OME sells which gives about a 1"lift.
It is true that OME bushings on most OME lifts do not provide stock caster numbers. My bet is that OME is well aware of this, they have likely driven/tested/evaluated rigs with their setups? My guess is, their goal is to make a kit that drives well, as long as used/loaded as designed. Once suspension and tires are changed, the “best” alignment numbers change, so what worked great on a soft suspension/tire stock rig is pretty much irrelevant, they are likely also aware of this.
As Slee has said hundreds of times, “once lifted/modified they are all different”, my experience agrees. They can’t be the same, too many variables, lift height, weight, where the weight is, the amount of body roll, tire construction/stiffness, driver preference, etc, come into play when evaluating the alignment for best handling. In my experience, shooting for the numbers that worked on a stock rig is often a great way to induce vibrations, often unnecessarily. I have setup/driven lots of rigs with less than “stock spec” caster that drive very well, comfortably, have also seen some “problem children” that required more, but they are the minority.
I'm going to disagree with most of this. Any 80 regardless of what springs are used at any given height over stock will require a given amount of caster correction. Throw in all the erroneous variables you want, but the resulting correction will be dependent on the lift achieved.
What part do you disagree with?
Also, how come nobody does a cut and turn like on a 60 axle? Sorry to hi-jack the direction of things, but it seems like you would have decent pinion angle and could get the castor where you want it without having to use spacers, CC bushings, or build arms.
the fact that these trucks as so different from truck to truck that at the same ride height they will need completely different caster solutions.
It just hasn't been my experience at all.
