Driving 100`s on Washboard Roads
I have flushed my system. My levels are good. I am at 7 gradations when testing the system. I suspect I will buy new globes and bushings soon and see if things improve.
Just replaced my globes which were at 7 graduations and am now back to 14 with an armchair ride. i highly recommend you get your AHC back up to spec and enjoy the ride.
A bunch of us are heading out to Death Valley in Nov and one rig with be an LX with AHC so will get some live data then compared to my Icons.
For tire deflators I use these
https://www.amazon.com/dp/B00QBPBLWY/?tag=ihco-20
Where in DV are you heading? You want to test your suspension and washboard roads head to Saline Valley!! PM me if you want some info. Have fun!!
Thanks. Doing the Big Backcountry Loop, Panamint Valley, over Mengel Pass, West side if open, Titus, Racetrack, Eureka Dunes, Steel Pass, Saline Valley. Have done pretty much all of it before. Depending on conditions Racetrack Rd or Saline can have the worst washboard.
I run ToughDog 53mm fronts and 45mm adjustable rears (both foam cells). On washboard, I run 23psi (275/70/18 KO2) and find the ride "bearable". Speed tends to make them less jarring. Given the oversize nature of the bores in my shocks and that they are foam cells, they are significantly less prone to overheating than traditional shocks. I think of them as a little more than 60% of the way to a true remote shock setup. The thing I notice most about quality shocks is that when going through sweeping turns on corrugated gravel, the rig stays planted and doesn't want to skitter off the trail. Much more controlled.
Out of curiosity since I run the exact same Tough Dog shock setup as you, what setting do you put the rears on when you hit washboards? You have far more weight in the rear than I do, but at least I could get an idea of the optimal adjustment range when I encounter some whoops and want the ride to be as smooth as possible.
I run 8 on roads, 4-5 on corrugations and 3-4 on rocky trails. I've found those settings to be ideal at my weight setups. I also run the dual-rate 660# coils from Jason FYI.
What setting do you set for wash boards, sport setting or comfort or either 2 settings in between? Thx
You need faster rebound to handle washboards. When I had my AHC I would run it one notch in from firm/sport (from right to left, the 2nd one from the right) on washboards and then lower the psi in the tires to 24. I found that if the AHC was in the bottom 2 settings, the suspension would "pack-up" on washboards and start getting rigid quick. Pack-up is the concept that the shock can't rebound quick enough to gain back its full stroke length. After enough cycles of the shock not rebounding properly it gradually sinks lower and lower and loses its travel. Ideally, we'd have both compression and rebound damping like you see in more advanced suspensions.
I'd think the best we can really hope for is:
Low spring rate, digressive shock valving, balanced droop/compression, low tire psi, sway bars removed (only if LONG day of washboard), good condition bushings, and loud music.
Why digressive valving and why remove swaybars?
Thanks for the information. I'm hoping dropping to 18psi should help. Looking forward to hitting some trails this long weekend to dial it in. Have a great one!
Reservoir shocks can handle the heat. Run 15 miles of washboard, then touch the shock body of your factory shock. I usually run 2wd, unless the washboard is bad and the road has lots of curves you are trying to take at speed....then 4wd.
Just don't try and "corner" or "rally-drive" with psi that low. The Scandanavian flicks we do in rallying will roll a tire off the bead at those psis unless you have beadlocks.
Digressive valve shocks are more responsive to small and initial movements in the shock. On an aggressively tuned progressive shock, the valves may not even have time to properly open on washboard as it is a small movement in the suspension travel. Icon shocks are digressive. King and Fox are progressive.
And removing sway bars allows the front end to move independently and more freely. Simple as that.
I think you have that backwards? Progressive shocks have very light damping for small velocities and more significant damping for big hits. Digressive valving is aggressive for small velocities but doesn't increase much with higher velocities.
I wouldn't disconnect sway bars.
I was mainly going off of prior knowledge that Icon’s are known to handle small bumps better. But after reading some, it appears I was incorrect on several accounts. Kings and Fox’s are a linear shock.
Good article for anyone wanting to read up on shocks: https://accutuneoffroad.com/articles/digressive-vs-linear-vs-progressive-pistons-shock-valving/
And the sway bar would help quite a bit as it allows for independent suspension movement, but you suffer handling.
