I had hoped to cure my driveline vibrations when I found and replaced the missing driveshaft bolts on my 1961, but the problem was still there, only not as severe.
The vibrations got worse again, though, and I crawled under to have a look the other day. While pushing up and down on the rear driveshaft at the t-case yoke, I noticed the output shaft on the t-case moves quite a bit!
While absent-mindedly tugging on the d-shaft, I notice the whole t-case/transmission rocking up and down
The tranny mounts look old, but not broken or missing any rubber, so I crawl forward while still watching things move. My clutch inspection cover is missing (who knows when that went AWOL) and I see that my bellhousing is cracked through at the bottom edge and flexing.
Maybe someone has some helpful hints for me. I use the Cruiser as a nearly daily driver, but I have other vehicles to drive for however long it take to repair the damage.
Should I try rebuilding the transfer case and replacing the bellhousing? I should add that my transmission is pretty noisy and is tricky to shift, although some of that may be due to a worn clutch.
Alternately, maybe I swap out for a later 4 speed/ Tcase from a 40, along with the rear end?
FWIW, I've done engine, electrical, and body work, but I've never done a thing to the driveline on any car, so this is new stuff to me
