Driveline angle question
Lutz, FL
I am trying to setup the drivetrain in my 40 and was wondering what the best way to measure the horizontal angle of the tcase flanges? Any help would be apprecciated.
thanks
I believe he meant the horizontal axis so you dont get any driveline vibrations
well, the horizontal axis is only 90 degrees away for the much easier to measure vertical driveline and tcase flange.
Just match up the angle on the t case flange with the axle flange. If ya run some soft springs then tip the axle down (steeper) 2 degrees less then the tcase.
