love2fly
Flying the Mountains of the NW
I wanted to share my second built drive shaft rock protector cage. I just had a D/S tube replacement that reminded me of the first time I had to replace the center tube of one of my FJ40s D/S due to a good size rock that whacked the rear part of the tube leaving it with a wobble and out of balance. So I built a D/S cage. That was an easy one to do but this has a longer D/S so it a little bit of a challenge. My 45 had the dent already but was passed the limits of what Toyota calls for on run-out (0.8mm) as mine was at 1.6mm on the run out scale. Now some say why do this as its now just a road snag now or something else that will crush on a high center climb when 4x4. Well first of all I am not a rock climber (use to be) with my 45. I plan on spending a lot of time on the jeep trails in the state I reside in, and we have a lot of trails. Most all have primitive rocky roads and that sound of "ding" while driving on the rocky roads tells you that your D/S just took a round. So to help eliminate the cost of re-tubing the D/S every winter after a full summer of fun, I installed the D/S cage. When completed it is tight with no vibrations and so far works perfect. The rear is the lowest part of the cage but still 2.5" above the differential houseing (from the side view). I took the rig out to the local rock pile were one can test the suspension and I had it in every contortion I could get it into. Took the measurements and put it into the cage configuration's and have about 1.5" of clearance between the cage and D/S at the max drop of the rear axle. I have some light wire mesh that goes across the top of the cage opening to help keep the rocks from bouncing into the cage and doing the PING PONG BALL thing as seen on the lottery's, and I have some all weather close-cell foam that I am going to cut out and install with glue at the front of the cage opening were it will have 1" clearance around the D/S tube. Oh yeah, if it is mashed it comes off with six bolts. Just getting ready for the trails this summer maybe this will be helpful to someone or maybe not.
Happy mudding.
More picture if you want
Happy mudding.
