I have an '09 with 211,000 miles that just manifested the infamous radiator crack. Dealer has quoted me ~$2000 to replace, including a new water pump, thermostat, and coolant. Does this sound about right?
Sounds high to me. Radiator, hoses, new host clamps, two gallons of coolant and the labor is about $750 at the dealership I used. Water pump and thermostat is another hour or so of labor I think. I'm not sure the water pump cost offhand but maybe $200-300? Seems like anything over ~$1200 is awfully expensive to me
Strange since the Factory Service Manual (at least for the Land Cruiser) has it coming out the top. I've had to remove or at least extend the front clip (Audi service position, for example) on other vehicles, but not sure how you'd do that with the 200.Water pump was $121 at my local Toyota dealer. I was just in there today getting my defective radiator warrantied and they mentioned that when replacing the radiator at the dealership they are required to removed the front end or corporate will not back their work and parts. No dropping the radiator in from the top. At least this was their story.
If you go this route I would make sure serpentine belt, idler puller and tensioner are being replaced as well. They are cheap parts and MAYBE 15 extra minutes of labor if you are already doing everything else. (Source: I just did all these a week ago. It was all surprisingly easy.)
Has anyone tried some jb weld as a bandaid? Unlike BMW, these radiator’s are not under high pressure.I have an '09 with 211,000 miles that just manifested the infamous radiator crack. Dealer has quoted me ~$2000 to replace, including a new water pump, thermostat, and coolant. Does this sound about right?
Total BS.they mentioned that when replacing the radiator at the dealership they are required to removed the front end or corporate will not back their work and parts. No dropping the radiator in from the top. At least this was their story.
Correct. You can’t. The core support is welded on, so even if you removed the bumper skin and other front end parts you’d still have to drop it in from the top.Strange since the Factory Service Manual (at least for the Land Cruiser) has it coming out the top. I've had to remove or at least extend the front clip (Audi service position, for example) on other vehicles, but not sure how you'd do that with the 200.
Read the big thread. People are having good results with a couple types of patch as long as the repair is done before it starts leaking.Has anyone tried some jb weld as a bandaid? Unlike BMW, these radiator’s are not under high pressure.
