used to smoke in the lemon all the time and you could smell the fumes as soon as you opened the door.duracell said:HOWEVER IF YOU SMOKE AND HAVE OLD HOSES i WOULD DO THE WORK TO MAKE SURE THERE ARE NO LEAKS.
owensexport said:I used a Holley dragster fuel pump to pump fuel from
the main tank into my LV tank mounted under the
bed (where the spare mounts on the long bed).
Using 2 check valves and wiring the pump with a
DPDT switch, you are able to reverse the pump and
either fill the sub tank from the main tank or pump back
into the main tank from the sub tank!
