I had a Downey/Mark A. Header on my F engine and it mated fine. I am swapping in a 1981 2F engine. As I was bolting up the header to the 2F, the bottom of the manifold does not mate to the block because the manifold sits on top of the header where the 2 bottom studs are. It appears that I need to shave quite a
bit off the manifold to cleaner the header. Before I do that and potentially make a fatal mistake, I would like to confirm that cutting off some of the bottom lobes on the manifold is the correct action. I am using the 1981 2F manifold.
