- Joined
- Sep 17, 2003
- Threads
- 65
- Messages
- 4,457
- Location
- Sunnyvale, CA
- Website
- www.george4wd.taskled.com
Executive summary: Installed a Slee front drive shaft several months ago. The 80 spends most of its time 'resting' but when driving it makes a noise. Vehicle is lifted in the 4" range. 97 CE
Ok, so some history. I changed springs a year or more ago and the growl from running stock driveshafts was obvious. Growl on deaccel. Couple years back had changed all unijoints with new.
Figured the front definitely needed a double cardan, so after the upgraded coils I spent more $ and ordered a Slee double cardan. Install went smooth and had put some grease in, just in case it was shy of some being new. Went for a drive and it seemed 'ok'. Anyhow, from the next drive and as time as gone by and I drive the 80 (once every couple or so weeks) for a short work commute, maybe 3 miles each way and surface roads (35 - 40mph max), it makes a ticking/ringing sound that is correlated with vehicle speed ONLY on acceleration. Lift of the accelerator and it is smooth as can be and quiet as can be, touch the accelerator to put a load on the drivetrain and noise is back. The shaft is not rubbing/tapping against anything.
Today, after a bunch of procrastinating, I dropped the front shaft and locked the center diff and went for a few mile drive. All quiet, no ringing sound, all smooth, all perfect, other than now being a 2wd vehicle
I need to give Christo and gang a call Monday to get their thoughts, but figured I'd see if anyone has had the same issue and/or thoughts of "why is it so".
It is installed with the witness marks on the shaft aligned as it was received from new.
cheers,
george.
cheers,
george.
