The general dynamic is that that suspension will trend towards toe-out when compressing. Caster also increases. So when AHC hunkers down to N2, there may be the slightest bit of added toe towards toe-out and an increase of caster. Emphasis on slightest bit.
Both deviations can be desirable at speed.
It may trend towards toe-out, but then there is more HP being put down as the driveline works against aero loads. That'll tend to pull the front axle towards toe-in which may neutralize any trend towards toe-out as it lowers.
Caster increase is good as it provides more steering stability at speed.
With all suspensions, there's a sweet spot in travel where toe-steer is minimal. That's important as the suspension is designed to cycle and absorb irregularities. Can't have the alignment change dramatically with just a little bump. So these dynamics have already been considered in its design that we don't need to re-engineer it.
Unless we start mucking up stuff with aggressive lifts and such. Which is why I'm a firm believer in less is more, and stay away from large static lifts that really impact geometries.
The OEM toe spec is pretty tolerant at -0.17° to 0.17°. My preference is to aim towards neutral toe.
