Do riveted M416 wheels leak air?
Hugh Heifer
What we gonna do today, Brain?
Rome, GA
Website
www.stlca.org
Getting ready to put tires on my M416 and was curious if anyone had problems with radials leaking air thru the rivets on the old rivetted M416 wheels without using a tire tube?
:cheers:
I ran set of standard trailer tires on the original M416 wheels for years with no tubes and no leaks, I even towed the trailer from Maryland to Arizona like that with zero issues.
I can 2nd what Henry said as I run a set of tubeless tires on my M416 with the stock rims at this time . It sat for over 3 years in my shop with a load of parts in it and they didnt go flat . They were low (about 20psi when I would run them at 40)
I think the only thing was the rim used a larger stem then a normal rim but I found it at a big chain auto store on the wall so should be not a problem for your tire shop
After getting my rims powder coated, I ran a stripe of POR15 around the middle on the inside where the rivets are. This is where the powdercoater hung the wheels so there was a small strip not coated. I figure the POR15 will further protect against any leaks if it was even feasible for leaks to occur.
