climber8483
I am finally gettign around to doing the rear brake conversion i got one i bought the rig from the PO. The box only had 1 crescent moon looking shim. The kit is used as the brake pads have a little wear and you can tell where the shims were previously mounted. They are only about 1/16" thick. If i need them can I use washers instead of the chim or do I need to see if I can get some fabbed up? Being that I am doing the work in a parking lot I would rather know if I need them before I pull it all apart.
Thanks,
Brittain
Thanks,
Brittain
