do hilux rims fit my fj70?
Aruba
i can get a set of nice rims from a hilux that my neighboor flipped for a good price but my fj70 is in the bodyshop so i cant see if they fit can anyone tell me for if they do i think the hilux is a 88 or 89 and mine is 91.... so thanks already
Size of the rim. please! :D
Landcruiser 70 series must have offset of min -20.
less than that will required a spacer.
okay thanks is there a way to measure that?? because there is nothing written on them
Hi All:
If the Hilux has a solid front axle the wheels will work on your FJ70 as is; if the HiLux has an IFS (Independent Front Suspension) front axle then wheel spacers will be required.
Regards,
Alan
While we're discussing rims, do you have any idea if wheels off a 1980 Hilux(solid axle) fit a 80 series(93 model)?
Thanks
Hi All:
Thread highjacker :grinpimp: Cmoney: IIRC the 80 Series uses a different back spacing than earlier 40/45/55/60/70/75 Series TLCs. So the bolt pattern is the same, but the off set is not the same.
Regards,
Alan
Thanks
if the wheels are 16",they will fit but it will stickout about an inch,15" wheels will not clear brake calipers on 93 80 series.
