DIY MFC pour spout
baldilocks
Battle Ground, WA
GOLD Star
Battle Ground
I bought a couple used military fuel cans on CL but didn't want to spend $50+ on a pour spout. I already have a super syphon which works well with the fuel can sitting in the bumper basket on the drivers side but I figured it can't hurt to have a pour spout as well if it could be done cheaply.
It tested well emptying a full can in under 90 seconds with zero leaks and easy operation. CARB would be proud!
1 each reducer 2"x3/4"-$2.29
1 each 5/8"x3/4" male, barbed hose fitting-$2.49
1 each 2" pvc cap-$2.79
1 each cork-$.49 (plugs the tank end while not in use)
2 feet of 5/8"IDx3/4"OD braided pvc hose-$2.98
Actual results may vary.
Same. Use mine once per week when I drain my MFC to put fresh gas in.
I bought the actual donkey di(k for the MFC's and it doesn't fit Past the restrictor lol, used a autozone spray bottle with the bottom cut off to fill my tank while hunting last year...when I realized the filler neck wouldn't work.
So does this improve you MPG, or are you still fighting the metric gas wars @NLXTACY
