Got to refreshing the front end suspension with new UCAs and LCAs. Planned to have Gyraline in hand just for this occasion.
Setup on alignment plates on front axle and leveling ramps in the rear.
Gyraline has been updated (v2.22.07) since I've last used it and seems pretty polished. Looks like they acknowledge Android phones are not useful for alignment and are coming out with a Gyraline G2 with external precision sensors to support Android (at a much higher price point).
Apologies as I was in a rush and didn't get before and after specs as I realized later screen saves in app weren't working. Also adjusting alignment might be more difficult than most want to tackle as it's a fine balance of caster, camber, and toe. In a maxed out config like mine, I can eek out just enough in every parameter, but would be hard for someone starting from scratch to learn the app, learning the mechanics and art of alignment, and what to aim for in a 200-series.
That said, the app worked great for my needs. Took about 2 hours between 4 adjustment and measurements to get where I wanted to be. Then put her on the road for a 300 mile off-road trip. Nailed the alignment in one go it performed flawlessly to my amusement.
Caster on both front wheels measured 2.8 (which is fine on 37s as it's more about the length of mechanical trail)
Camber measured
-0.05 on left wheel
-0.04 on right wheel
Toe
EDIT: Adding more detail. Toe is the most important parameter and probably the hardest. Difficultly is that it's hard to establish a datum (reference point) that points truly straight and center relative to the vehicle. Versus camber and caster where it has absolute level as a datum (provided the ground is level). The app is best at comparing a previous surface to the next surface. Additional surfaces create tolerance stackup and drift.
There's two modes - body align (first pic below), and thrust align (second pic). Both are useful but helps to understand they use different references.
