Distributor dedicated ground
Chicago
I’m in the process of installing a new distributor. It has a white wire “dedicated ground” that runs to where the coil is mounted on the right wheel well. I have plenty of wire lead, where is the best (cleanest/stock ) installation to route and connect it to the vehicles ground?
Thanks,
Sam
The other distributor wire runs up to the Coil, there is a nice bolt there can be used as a ground, so you could run both wires up to the Coil for a neat appearance. There is of course a ground on the engine as well.
