As part of my 1975 2F rebuild project, I'm now at the point were I need to make some decisions about the distributor. I'm going to be using the carburator, intake and exhaust manifolds from my '72 F motor on the 2F and I'm wondering if I should use the distributor from the '75 2F or the '72 F?
The numbers I found on the '75 2F distributor are 19100-61021 and 029100-4101. My other question is, if I use the 2F distributor, does anyone sell a rebuild kit or would I need to purchase parts individually? I haven't started cleaning the 2F distributor yet but here are a few parts that seem to be no brainers for replacement:
- Vacuum Advance Assembly - dented
- Vacuum Advance Set Screw - bent
- Distributor Cap Springs - one missing
- Spring Latch Screws
- Distributor Cap
- Rotor
- Points
- Condsener
- Distributor O Ring
Are there any other obvious parts that should be replaced? Thanks.
- Distributor Cap
- Rotor
- Points
- Condsener
