Wow, the more you look into diffs the deeper and more of a maze of different bearings and kits and pinions there is.
I got a drivetech diff kit with bearings, crown, pinion and flange the whole kaboodle, crush sleeve too. It was a good price, I thought. $6-700 ish aud The crown and pinion are beautiful italian jobs.
But! Aftermarket kits may supply a different sized pinion, this one is wider, than the oem, so different bearings fit rather than the oem ones. On top of that, an aftermarket solid spacer shall not fit another aftermarket manufacturer's pinion.
So, I was in the process of making a slip bearing so I can get depth and preload correct without having to press them off and on each measure, but the aftermarket outer pinion bearing is a totally different id to match the aftermarket pinion. I found a few good value koyo's for the inner pinion bearing, not too painful. It is an expensive nightmare to hunt down some of these exotic sized bearings. On top of that, if I want to proceed with a solid spacer I'll have to hunt down one which fits this pinion.
Well, I guess I am still a little ahead as oem crown and pinion alone is close to $1200 aud , $$$. But finding the aftermarket bearings to fit the aftermarket pinion I am looking at $120 aud a bearing and the toyota ones are around $27 aud..what a maze.
I thought I'd post this link to give a sample of what pro diff folks have to refer to! Learning is painful.
