I tried to do a search but everything that comes up is about the VSC light malfunction. What I am wondering is what are the recommendations/guidelines for when to turn on the diff lock or off (for example on ice or snow)?
The way I have been using it is to just drive in normal mode on wet roads and even in some snow where it is sanded or pretty good. Once I am at slower speeds on icy/slippery surfaces or deeper snow, then I click the diff lock button. Is that what everybody is doing? Here is what the manual says...
"H" (high speed position, center differential unlocked):
Lever at "H", center differential lock button left out
Use this for normal driving on all types of roads, from dry
hard-surfaced roads to wet, icy or snow-covered roads. This
position gives greater economy, quietest ride, least wear and
better vehicle control.
"H" (high speed position, center differential locked): Lever
at "H", center differential lock button pushed in
Use this for greater traction when you experience a loss of
power, such as wheel slipping, in the center differential unlock
mode.
"L" (low speed position, center differential unlocked):
Lever at "L", center differential lock button left out
Use this for maximum power and traction. Use this for climbing
or descending steep hills, off-road driving, and hard pulling in
sand or mud.
In this mode, the braking feeling that occurs when the wheels
are negotiating a sharp corner is further reduced than in the "L"
(low position, center differential locked) mode.
"L" (low speed position, center differential locked): Lever
at "L", center differential lock button pushed in
Use this for maximum power and traction. Use this for hard
pulling in situations the vehicle cannot negotiate even in the "L"
(low speed position, center differential unlocked) mode. Also,
using this mode when driving down steep off-road inclines will
help contribute to increased vehicle stability.
mode.
sand or mud.
