Diff breather kits
Usa
Who all has experience with the ARB and Air On Board (AOB) diff breather kits? These both appear to come with a thinner plastic-like tubing as opposed to rubber hose. Since 80 Series front axles have the rubber hose that clamps to the nipple coming out of the axle, would the 1/8 BSP M to 1/4 PU fittings screw into the axle housing? I’m wondering if these kits are worth the trouble basically.
Most of the kits are good bling, but are less than ideal. I'm not a fan of venting gear boxes together, risk of cross contamination and in the event of contamination, can't tell at a glance which one has the problem. Each box should have it's own breather, it's cheap and easy to do, some 1/4" hose and small fuel filters.
Couple feet of 1/4" fuel hose and cheap fuel filters are probably fine!
Just did my diffs with 1/4” vacuum hose and small filter. Ran the rear along the frame. Used a T to connect the front then into the filter. I also attached a hose to the filter output and coiled/ drip looped it to prevent water/mud getting into the filter. I attached the filter and coiled hose with zip ties by the brake booster to the frame. I bought 25’ of vacuum hose, box of Ts and a filter for just over $20.
DIY diff breather kit is a rite of passage. Low cost, very effective, no frills. On mine I went with fuel line but vacuum line probably will work just as well. As @Tools R Us mentioned there's no need to tie them together.
We run the front ones to the firewall over the brake booster.
breather-jpg.860003
The rear into the jack compartment, over the fuel fill hose. The second hose is for the rear locker actuator.
joe_70-jpg.1681161
I just reused the factory breathers after extending the line. Then rebolted it inside the engine bay.
The rear I just moved up to the bottom of the body, I don't plan on going in deep water past the body.
Reason I didn't reuse mine is the front was clogged and the rear had some resistance. I almost went and bought 2x replacement rear valves, but ended up just using the fuel filters. I might go to the OEM ones in the future.
