So here's a new one - I just did an AHC Flush today; the front is bouncy - I think the globes are shot. I checked the graduations, only about 6 or so. Meaning globes need replacement. But had the fluid so I tried to flush anyway to see if it would help in the time being. Here's what happened:
I emptied out the main reservoir, but only got the accumulator and ONE rear globe bled. The reason for this is that the other globes drain nipples would not open properly - I used the same 10mm wrench on all of them, for some reason the 10mm nuts were soft (probably due to a bit of corrosion in those areas), and wouldn't open properly, they started stripping upon trying to crack them open. The frame and majority of the underbody has very little rust, it's in quite good shape given the year - but the ahc components are not in such good shape. It's probably about 21yrs old (2000 model). Also, the front shocks are totally shot, they look quite corroded. The system raises/lowers very quickly, but makes large adjustments, and quite often, and drives bouncy in the front. Rear feels soft and composed like my old LX. Front feels different (worse).
I think I'm going to switch to a standard (non ahc) suspension.
I have a few questions. Maybe I should post a new thread on this? Not sure. Here goes:
1. Front: I will need sturdy TB's for the front; heavier duty than factory US landcruiser setup, due to added weight of the diesel upfront (it's 200+lbs heavier than 2UZ engine). I'm not planning on a heavy duty front bumper (at least anytime soon), so where would I source the best deal on a bit heavier duty TB's? OR should I go factory toyota setup for HDJ100-FTE? I could probably source that out of Europe/Aus or anywhere else - OR perhaps OME/ARB be suitable for this...
2. Rear suspension: I want to keep a fairly composed ride, but I found my old LX470 factory suspension too soft (in general). If I want a setup to ride like the LX in sport mode, what should I do? I figure I could go to any competent aftermarket company for this. Perhaps a bit heavier spring rate might help, provided it's not a ton stiffer. Even if I go stock toyota, and add spacers that might work too.
NOTE: I don't mind having 1.5-2" lift, but don't really want more. Not sure if I'll need a diff drop kit for that.
Cost/quality ratio is important. I'm looking for best price/performance here. I'm not doing any rock crawling at this point, and I WILL take it offroad, but not through majorly harsh stuff... Mostly FSR's and the odd medium trail, but that's it. I do not want cheap ebay parts either (naturally). Something reputable, but reasonable.
For reference, I had a Bilstein 5100 suspension/shocks on my air-ride equipped toyota sequoia previously, and LOVED The way it drove - but I don't see a bilstein option for mine, notwithstanding the extra weight of the diesel engine up front.
QUESTION: What do you all think about this, and if you could make any recommendations?
