I just finished a ~2000 mile trip, and am alarmed to realize how unevenly my front tires have been wearing. The outer treads of both front tires is worn nearly 1/4" more than the inside. This is a new development, as the tires had been wearing evenly for 21,000mi until this trip. I have a matched spare, and have diligently rotated all 5 tires at ~7000mi intervals, including immediately before this trip. BFG KO3s, if it matters, inflated to 37psi.
Here's where the clues come in - I overhauled the power steering and replaced the tie rod ends right before this trip. Finished off by rotating the tires, and then straight to a shop for an alignment a week before putting the miles down.
So did I get a bad alignment? If this was a different vehicle, I'd say it has bad camber adjustment. But... camber isn't adjustable on these, right? I definitely had a toe-in issue after the TRE install, but that's what the alignment was supposed to fix. After the alignment, the truck felt waaay better than before (but maybe a little squirrelly still?).
Another detail, but I'll need to be convinced that this would account for the tire wear: I was towing a small utility trailer (with rooftop tent) for this trip. And we had strong cross-winds in the columbia river gorge (as you expect). Probably 700mi driving in consistent crosswinds at highway speeds outbound, and 700mi similar from the opposite direction going home. Could that explain it? Not sure whether I hope this explains it or not.
Any other ideas? Wheel bearings? Bent axle housing?
