this is not hardcore, but I need hardcore help as I have exhausted the 60 section.
I bought a new/used EZ Locker off Craigslist(under the impression it was a Lockright as it was in a Lockright box)
1990 FJ62, 188k: Installed it, resealed and oiled pumpkin, put it gear and the d-shaft just spun and ratcheted, not moving the vehicle. vid taken after removal of dif cover, neutral then "drive" after second 7...
space between drivers is 3mm, under the Lockright tolerance of 3.6mm, the locker looked brand new but I'm thinking it might just be worn out. it is assmebled per manuf. specs, including thrust washers, c-clips etc.
you guys have any ideas of the cause? if I can't get it rectified, I'm contemplating welding it up and creating a spool, saving my spiders in case I ever want to restore it to open.
here's my original thread with more pics and advice.
https://forum.ih8mud.com/60-series-wagons/506417-lockrite-aussie-locker-install-issue-help.html
thanks!
thanks!
