Wanted DESPERATE FOR TRANSFER CASE
JBER
I screwed up. I tightened the t-case bolts to the tranny incorrectly and split the case.
I'm behind schedule on this build and really need a deal on the juat the case itself.
It can be from a 60 if it'll fit, or even from a 3 -speed if they bolt up.
They all want way too much money on eBay.
Need help! Thanks
Cale
9524862947 if in MN or nearby state
Need help! Thanks
Cale
not knowing what transfer case you broke, it will be difficult to get you the one you need.
1 split case will not work where a 1 piece transfer is needed.
It's a 74 2F with a 4-speed and 1-piece transfer case. Ill update the spline count later. Sorry for the vague listing. I put up a few local want ads as well and have been a bit flustered knowing my mistake will likely cost me $400+ more dollars and 2 more weeks of downtime
Marks off road in CA has them for sure. Try Valley hybrids in Stockton as well.
Can you just weld the case?
I believe I have the exact transition case you are looking for, but I will not be back in the shop until Monday. Hopefully you can wait until then.
Sounds like I have a few options so that's good. It depressed me quite a bit when the case split. Powder coated, fully rebuilt, a millimeter away from being billed up and then POP!
I'm going to check locally first but I'll definitely hit you up if it doesn't pan out. Right now, cost is a huge issue.
