- Location
- United States
1995 Toyota Land Cruiser for sale. Sad to see it go but need something with better gas mileage. Drove this Cruiser from Denver to Seattle to LA to Vegas and back to Denver last Fall with no mechanical issues whatsoever. Very reliable vehicle. All stock. Asking $8,000.
Pros:
- four brand new tires (purchased and installed in June '19)
- front brake pads, rotors, and calipers replaced December '19 (~$1,200)
- triple differential lockers
- new battery/terminals in October '19
- dark, high quality LLumar window tint installed August '18
- bluetooth head unit
- front seats and center console reupholstered
- brake hoses replaced May '18
- valve cover gaskets and spark plug tube seals replaced July '18
- passed CO emissions inspection May '19
- ice cold AC, hot heat
- replaced rear hatch struts
Cons:
- Has a slow oil leak. It leaks about a quart every 1,200 miles or so. I'm fairly certain it's due to the distributor o-ring that needs to be replaced.
- Rear passenger door lock does not lock electronically. Works fine manually.
- Some light hail damage and faded paint on the hood
- The CarFax shows there was a possible odometer rollback between 2000 and 2003. The odometer currently shows 170k but actual mileage may be closer to 220k.
Pros:
Cons:
