Dang, that DHPM 31 Deal seems to have ended at midnight. However, check sears.com every day. There seem to be frequent, brief, good deals online for in-store pickup. If I'd known that 31M would fit nicely I would have grabbed one.
Since its back up I have another question. Will they charge properly with the stock alternator?
Sent from my Nexus S using IH8MUD
itbrokeagain said:Since its back up I have another question. Will they charge properly with the stock alternator?
bugsnbikes said:the big advantage of a true deep cycle battery is that it can take as many amps as you can feed them. ie- if you happen to get one of those Tundra 150amp alternators- you could theoretically recharge those batterys twice as fast compared to the 80amp cruiser ones.
Theres a product made by Promariner called the "digital mobile charge series" which actually will trick the alternator into thinking theres a low charge on the batteries and will automatically switch your alterator into charging at its highest amp rating. Good if you have a tundra 150amp and want to dump a full load into your deep cycles even if they arent fully drained.
- Deep cycles dont like to be drained below its 50% amp hour rating. So if you plan to regularly winch off them.......then you need to double up the amp hours and ONLY drain them 50% and have some type of monitoring system to know that you arent overdraining them on a regular basis. If just for emergencies-and the oddball full drain- youd probably be okay--but you probably dont want to be dropping them below 40%capacity on a regular basis. Same is true for running fridges/etc.........so in your calculation for amp hours and what you are trying to do with your deep cycles- the 50%drain is about best for them.
For winching- a high CCA backup is probably better as they dont mind getting pushed well into the full drain repeatedly. The size and weight of a deep cycle that at 50%drain can put out close to the same CCA will be prohibitive under the hood size and weight wise.
Incorrect. Deep cycle batteries are able to supply and take up a charge slower than sli batteries due to their thicker plates. AGM batteries are able to take about twice the charge rate of standard lead acid batteries, as well as offer about twice the number of deep discharges as a lead acid battery. That is why they make sence when used for winching.
Sent from my iPad using IH8MUD
