So my TLC has been "resting" for a few years while I've been busy (nice to see the forum still active
On a few recent drives, I noticed the alarm (aftermarket CodeAlarm) would occasionally sound after starting the truck and I would hit the fob button to deactivate it. After a few more drives, it started happening WHILE I was driving (my kids call this the Ethiopian Landcruiser sound - as it seemed to happen a lot during a recent trip to Ethiopia . . . and they all thought it was cool and wanted to leave it
Not surprisingly, the last attempted drive found me with a dead battery. It occurred to me the aftermarket alarm has a feature which activates it if battery power is disconnected (I'm reminded of this when my ear is next to the siren whenever I'm changing a battery . . . ). No big deal, switched to the secondary battery to 'jump start' myself and pulled the main to charge on the bench for testing. The pattern repeated with the secondary winch battery and ultimately, I learned that the secondary was indeed DEAD (2-yr old Optima blue) and the main is fine (identical 2-year old Optima Blue).
Next drive was a bit longer (maybe 15 miles) mostly highway and no problems with the fully charged main back in place. But when I started the truck to head home, it started fine and then freaked out. The engine was revving from idle to ~2,000 rpm back and forth (continuous surging) and half the dash lit up. I shut it down, started it back up and everything was back to normal, but a few miles into the drive it returned (dash lit up like christmas and engine surging). I drove it home avoiding stop lights (surging revealed the need for front brake pads soon
and parked it. Checked the battery and it was at 11.73 volts. After a lot more thinking, a few days of IH8MUD forum researching, I concluded that the alternator was toast. I also decided I was too busy (pronounced 'lazy') to fight the Sequoia alternator into place, so I went about pulling the old original alternator for testing.
This thread has all the links needed for someone just starting the journey:
https://forum.ih8mud.com/threads/another-150a-alternator-and-wiring-upgrade.608585
After taking my alternator to several parts stores, I learned that it is dead as possible. In fact, all three tests show as FAILED (Lamp/Diode, regulator, and Rectifier). But I'm left wondering, what the heck caused the entire Alt to fail? Why would a bad alternator cause the engine revving issue?
Other oddities also occurred that now seem to make sense . . .
So am I missing another issue I should check while sourcing a new alternator? Rebuilding the original seems out - I was up for ordering brushes, but with the diode and regulator also gone ...
As always, TIA.
- the power windows were super slow (they have been for a while and I have a set of window rubber sitting in the house for years waiting to be installed)
- the power seats seemed really slow (I figured I just got fatter in the years the cruiser sat, and I probably need to order some new while gear thingies . . . and lose weight)
- the aftermarket stereo would occasionally turn off while driving
- the wipers seemed really slow (I figured really old blades with hard / dry rubber)
As always, TIA.
