- Joined
- Feb 13, 2020
- Threads
- 90
- Messages
- 743
- Location
- Chandler, AZ
- Website
- www.wastingtimeinthewoods.com
Thinking through a more robust battery set-up. Been running a single AGM for house and start and it's been a bit limiting just keeping the fridge running. Keep running into voltage cutoff. Thinking about adding a 1kwh-2kwh battery system (ecoflow, Bluetti, etc.) as a house battery. Solar is slow and like a fully shaded campsite if I can find it. Ecoflow makes an 800w 'alternator charger' ($400), which I assume is just a Dc to DC charger. I'm wondering if a 2kw inverter would work as well or better. The new power stations all claim an hour or less on AC. I'd also have the added benefit of having the inverter to run a saw or cook off of if the battery crapped out, albeit with the truck running). The only issue is a 2k inverter would draw all of my 150Amps my stock alternator puts out...
Is anyone running an inverter on the stock alternator? Is running an 2K AC inverter off the stock alternator a pipe dream? @r2m, you've got a big inverter and 250A alternator don't you? Have you done any tests on amperage draw while it's under load?
I want to keep the battery as compact and portable as possible so thinking the commercial all-in-one units will be best for me and I'm behind on all my projects as it is so building one myself isn't appealing. I gues the drawback is I can't use a DC to DC charger directly with most commercial units... or could I?
