I suppose there's no better time to cleanup some things that have been bothering me while I am taking out the entire wire harness. I am far from a body guy so I'm having a hard time figuring out the best plan. I tend to want to try to do the "best" thing I can the first time around, with the goal of not having to re-do something again in a few years. I am not doing a full restoration that I'm expecting to win awards for. Would be interested if there's another forum y'all would recommend for this kind of stuff, I checked out our paint & body section and it was a little quiet in there.
Back to my project, I think I have 3 unique scenarios I'm trying to work on. Under dash rust that can't really get sanded, engine bay that can kind of get sanded, and the dash which can easily get properly prepped and done "right".
1) Under dash I have alot of surface rust. It's obviously not an area that can get proper surface prep and prime and paint it right. Should I just get a wire brush where I can, maybe a wipe down, and get a basic rust convertor rattle can and go to town under there? Any brand suggestions or better ideas? Do you then paint over the rust convertor, or just leave it as is? Are the brush-on rust convertors better performing than the rattle can? Does it really pay off to get the surface prepping in, or does the rust converter stuff work pretty good afterall?
2) When I finally pull the last bit of wire harness out, I am considering freshening up the engine bay too. I can def surface prep better than under the dash, but it's still not going to be great access with the engine still in. Frankly I am also not interested in spending 10 hours of surface prep time to do this since you can see it's all kind of an embarrassing mess in general. Do I just get those sanding sponges (80 grit?) and scuff up where I can, wipe down, and then do the basic paint and primer? Is there a big difference in performance between rattle can and a spray gun for this application? Is there certain paints/brands I should be looking for? Any tips or suggestions?
3) I welded about a dozen patches in the dash from who knows how many previous owner's adding old switches, indicators, and whatnot. I would like to spend a little bit of time here to test my skills here.
I kind of got overwhelmed watching some of the Eastwood company's youtube videos talking about high build primer, body filler, glazer's etc. For my level of detail to this project, I think here is what I gathered I need to do, please correct where wrong.
I already have a compressor, DA sander, buffer, etc. After writing this, I am thinking about rolling it outside and just getting a Harbor Freight sand blaster to help with the under dash problem and the engine bay. Trying to avoid making a big project out of it, but like I said I do like to challenge myself and see how "right" I can do something, and see if it's something that I'd like to do more or less of in the future. If anyone wants to make a suggested list of things to get I would definitely be appreciative!
- Ideally get it down to bare metal, 80grit-ish. I have some old filler to get rid of under the dash still. (Do I need to go nuts here getting it down to 100% bare metal, or can coatings stick to these other coatings ok?)
- Work out any remaining dings/dents with hammer and dolly (I think I did 90% of this already, but need to go over it again with a straight edge).
- Spray Epoxy Primer. (I assume if it's been a few days since I did the sanding I should hit it again quick?)
- I believe I read that within 72 hours of epoxy primer, I need to apply body filler. I guess I'll pick something off of eastwood's website? Any particular recommendations?
- Smooth down the filler so it's all flat. (80-120 grit?)
- Spray a high build primer, sand down again as needed (120-240 grit?)
- Spray base color, 1-3 coats. Then do I still do a clear coat over it? I don't think there is much clear on this vehicle to begin with, so I don't want to end up with super glossy dash board with the rest of it being some early 90's paint job. For this type of project, is there a decent different between rattle can and spraying?
