For Sale Dallas: 1991 Toyota Land Cruiser
Year
1991
  1. 80 Series
Mileage
221608
Color
rgb(251, 234, 199)
221K Miles
Current Inspection
Clear Texas Title
New:
Toyota Water Pump
Toyota Coolant Hoses - Upper & Both Lowers
Toyota Shocks
Toyota Sway Bar Bushings - Not Installed
Toyota Link Bushings
Toyota Front Brake Rotors/Pads
Toyota Thermostat
Toyota Fusible Link + 1 Spare
Toyota Distributor Cap & Rotor
Toyota Spark Plug Wire Set
Toyota Diff Fill & Drain Plugs Front & Rear
Toyota EGR System
Toyota Battery Box
Gates Belts
Kumho 32” Tires - Low Miles
Catalytic Converter
Denso O2 sensors
Switch Doctor Master Window Switches
Slee Tie Rod & Drag Link - Not Installed
Slee Knuckle Rebuild Kit - Not Installed
Slee Front Spring Spacers - Not Installed
Slee Bumpstop Drops - Not Installed
Bit more info:
Runs and drives perfect
Cruise Control intermittently cuts out
PO removed factor radio and replaced with aftermarket
PO removed factory front and rear seats and replaced with later model leather, factory 3rd row
Does have "shaky" driver mirror
Oil changed religiously
Reason for sale:
Needed something with more pulling power and better parts availability for long road trips
DM for more info
$4,000 obo
I know it's a little off putting, but the shop I bought it from confirmed sending unit is working as it should, so we believe it's just the gauge. I've put some miles on it since I've bought it and no issues so far.
Not too hard to hook up a mechanical pressure gauge and check. If it truly had zero oil pressure it wouldn't take long to see the results of that. Seems like a good price for a rust-free 1991-1992 with the MIGHTY 3FE. GLWS.
Has it been repainted? Any pictures of the birfs? Any other oil leaks to be concerned of? Lastly, is the AC R12 or R134a?
does the ECM get pissed off about the oil pressure?
Looks like a nice original truck Too bad about the rear bump. This one looks like a great weekend country cruiser. New tires and a detail job would really make this one pop. Price is right.
