- Year
- 1991
- Vehicle Model
- 80 Series
- Location
- United States
- Mileage
- 221608
- Color
- rgb(251, 234, 199)
221K Miles
Current Inspection
Clear Texas Title
New:
Toyota Water Pump
Toyota Coolant Hoses - Upper & Both Lowers
Toyota Shocks
Toyota Sway Bar Bushings - Not Installed
Toyota Link Bushings
Toyota Front Brake Rotors/Pads
Toyota Thermostat
Toyota Fusible Link + 1 Spare
Toyota Distributor Cap & Rotor
Toyota Spark Plug Wire Set
Toyota Diff Fill & Drain Plugs Front & Rear
Toyota EGR System
Toyota Battery Box
Gates Belts
Kumho 32” Tires - Low Miles
Catalytic Converter
Denso O2 sensors
Switch Doctor Master Window Switches
Slee Tie Rod & Drag Link - Not Installed
Slee Knuckle Rebuild Kit - Not Installed
Slee Front Spring Spacers - Not Installed
Slee Bumpstop Drops - Not Installed
Bit more info:
Runs and drives perfect
Cruise Control intermittently cuts out
PO removed factor radio and replaced with aftermarket
PO removed factory front and rear seats and replaced with later model leather, factory 3rd row
Does have "shaky" driver mirror
Oil changed religiously
Reason for sale:
Needed something with more pulling power and better parts availability for long road trips
DM for more info
$4,000 obo
Current Inspection
Clear Texas Title
New:
Toyota Water Pump
Toyota Shocks
Toyota Thermostat
Toyota EGR System
Toyota Battery Box
Gates Belts
Catalytic Converter
Denso O2 sensors
Bit more info:
Reason for sale:
DM for more info
$4,000 obo
