Hi All,
This is on my wifes 2005 4Runner, 2UZ-FE. 150k mi. Was hoping you could help me out on this.
CEL came on a month ago, cylinder 5 misfire. Pulled spark plug, looked fine. Assumed a failing coil pack. Got the Denso from Amazon and replaced it. Cleared code and now it came back with cylinder 3 and 5 misfire.
The truck doesn't drive any different, but has a slight miss. Coolant level is good and there is no coolant in oil. I just replaced the oil 2 weeks ago, and it looked great.
Next is a leakdown and/or compression test I guess. Bought the truck this year from a friend who was the original owner and babied the thing. I can't imagine a blown head gasket...? Anything else I should check that would cause misfire on two adjacent cylinders?
Thanks
UPDATE 9-27-17, STILL HAVING PROBLEMS. List of things checked
- Swapped coils and replaced spark plugs
- Checked ECU via FSM
- Verified timing belt did not skip teeth
- Cleaned MAF and TB
UPDATE 10-11-17
- Compression on 3&5 @ 90psi -- Possible head gasket failure.
Update 2-10-18
Confirmed blown head gasket between 3&5.
Update 2-23-18
Head gasket replaced, with valve job. 1 exhaust valve on 5 was burnt. small breach between 3&5 in gasket. Truck running like new again.
Thanks
UPDATE 10-11-17
Update 2-10-18
Update 2-23-18
