CV Axle replacement 100 series, Refurbished vs New OEM (1 Viewer)
Somewhere in Texas
My CV axles have a fair amount of slop in the joints. Jerks on acceleration. Front-end shake 45-70 mph that stops once cruising/not accelerating. I've looked at after-market parts and decided against them. I found, however, a company that refurbishes original axles (OEM) and claims they are just as good or better than a new OEM. Any thoughts on that? They are significantly less expensive. Has anybody used J&J Axle Supply remanufactureds in Santa Ana, CA? Any reasons not to go with this vs OEM straight from Toyota? 1 year warranty
I have no experience with J&J rebuilts but I run CVJ rebuilt OEM's out of Denver and am happy with them.
Maybe just check if they have a core policy. CVJ's core policy is that the cores have to meet a few condition
criteria like the condition of the splines and that (obviously) the cores need to be Toyota OEM.
I feel like if they're up front about only paying full core charge back upon condition being confirmed,
they're being picky enough about what they'll rebuild.
Thanks for the advice/tips!
If you're going to buy parts for an import truck, you should buy all the parts from the same international vendor. These CV axles, however, are the exception to the rule becuase their weight makes shipping + parts cost prohibitive, unless you can find someone who's already buying a container's worth of parts and convince them to add your to their order.
Absolutely no reason to buy all parts internationally for a non-US truck, esp. now with the deminimus gone. Anyway, if they're Toyota OEM axles they've refurbed, no reason not to try them. It's the cheap NAPA/Cardone axles that people seem to have the most issues with.
I can think of one reason: the parts aren't in US stock.
Get new OEM for sure then… or search for more Labor Day deals.
I just checked the old interweb and new OEM axles can be had for $320 each. Several places are running Labor Day free shipping sales as well. I just checked Serra Toyota and they are $320 shipped.
Highly recommend replacing the hubs at the same time, and make sure you get new C clips. Most likely size D or E with new axles, in my experience.
@Bisho I've gone through their site as well as others and the part numbers. They don't show fitment for any particular vehicle, but they do put the part number to the side. Every part number i check is for other vehicles. Yes, they have remans for about $320-370 on every toyota parts page. Most of them are for corollas and other models - even when I have the Landcruiser and its vin entered. Maybe I'm doing it wrong. If you have a link, drop it to me. I ain't looking for somebody to do all the work for me, but I'm not proud either. I'll click a link/learn a lesson.
nevermind I'm dumb. figured out what I had entered wrong @Bisho . THNX
It’s called a front driveshaft assembly, which is probably what throws you off. The price is further discounted as you go through the checkout process. This shows for a 2000, but they are all the same.
don't rebuild. the splines and flanges wear out. .. and they wear together. refreshing/rebooting is just a temporary state until the flange / splines wear out. buy new oem and new gem flanges.
I'll disagree, a little, with an "it depends."
I've rebooted inner boots at least three times. If a boot cracks and starts throwing grease, that in no way is an indicator there is something wrong with the rest of the axle. The inner shaft (part going into the diff) just doesn't wear out. You can buy the outer knuckle of the shaft as well, for 1/2 - 2/3 the cost of a whole axle, if the outer splines are worn. I've done that once. This all depends on how handy you are, of course, and what your time is worth. I enjoy doing the work, so I don't mind saving money when I can.
