cut n' turn mod (3 Viewers)
North Cadillac
I finally got around to getting this done. I think it's really a great mod. Now i can easily fabricate a skid plate from the slider. Here's the pics. One before and then after. :beer:
couple more. . . :beer:
By the way, it cost $70 and the guy fixed one of the hangers i had knocked the shizz out of.
much better!
anyone know why it wasn't like that from the factory?
NorCalDoug said:
much better!
Pink pantied concerns regarding passenger floor board heat!
Joe
Joe
There may be some heat on the passenger side, but it aint coming from no catalytic converter. :grinpimp:
Joe
So Joe, you're saying it's to keep the pink panties pink? Don't want to soil the pink panties now do we?
NorCalDoug said:
much better!
My guess is that in the factory orientation the majority of the radiated heat is not directed at the floor. With the cats turned for ground clearance, looks like 50% of the radiated heat is directly aimed at the floor. In the stock configuration the floor can get hot enough to melt the bottom of a plastic cooler! Some day I will get around to adding extra heat shielding.
I plan to do the same.
What are your thoughts on what to use and how to add more heat shielding?
I did this mod over a year ago and have never gotten around to adding a heat sheild. I dont see a reason for it. the floor may bet a bit warmer but iv done a 26 hour drive strait and its never melted anything.
Did you have to remove the slider to do it? Or did he work around it?
TJK
TJK
Worked around it. Did it really quickly too i might add. I was impressed.
Carry the load I do, and travel the roads I do, in the ambiatnt temps I do, and keep up the pace, and then I would expect that you would then see the reason. I'm not talking warm floor, I am talking very hot floor.
Two possibilities come to mind. 1) a section of sheet metal fastened underneath the floor fastened to standoffs for an air gap. The downside to this is it could be a mud & salt trap that would lead to corrosion. 2) A comoposite aluminized mylar foam type insulation installed inside underneath the carpet. This is perhaps the better approach, no doubt the easiest. Pull the seats, pull up the carpet, lay it down, and put the carpet and seats back in place.
Dude i live in arizona? hot hot hot. i drove from AZ to Bellingham Wa (top of the state. full load, basically everything i own (including a queen futon bed and mattress) going up to college this incuded a front passanger. did the trip non stop hit the desert at noon exactly. no complaints.
mike
not saying a shield is a bad thing just saying its not something you HAVE to do
120 degrees in the shade hot?
Seeing the bottom of a good quality plastic cooler melted by the floor mounted seat hardware is enough to establish the need.
