Custom RadFlo Coilover are here....pics included....
Southern California
Well the Radflo Coilovers have arrived!
Here are the pics....boy they are nice looking!
Cannot wait to get them installed!
Thanks Glenn!!
They look great!!!
Just wanted to give you a heads up on the install...It appears that on the Tundra at full drop, the lower pivot gets close or will touch the lower arm. Some arms require a little grinding for clearance depending on the shock make & how much drop the shock allows. You're probably ok with the LC, but might want to look for it when cycling the travel just to make sure.
Good luck on the install.
(FYI: Desert race in Barstow Saturday night. Might be a good opportunity to take it out prior to the race =)
The spring rate is 650lbs/in
