A couple of years ago I got a good deal on a Safari cast turbo manifold to suit my 1FZFE. But, now,I have the opportunity to get a really good deal on an externally gated Garrett turbo. (instead of internally as originally planned)
Because the manifold has no provision for a wastegate, and if I get the turbo I will need one, I need to figure out a way to fit one without getting another manifold.
So the question is, is there any reason why I can't have a 38mm hole cut into the manifold (there's enough room and thickness close to where the turbo bolts to the manifold) and have an adapter welded in to fit the wastegate to?
I'm not sure if the Safari manifold is cast iron or cast steel. If it is cast iron, I've read that steel can be successfully welded to it using nickel rods/wire and soft peening the welds to relieve stress. Anyone with experience on this subject is much appreciated.
I really would like to find a way to make this work because as far as I know, this is the only well made low mount manifold around - it just needs a minor tweak to be perfect.
