Cruiser Lean
Fort Smith Ar
Just did an OME 2.5 lift, thought it would level out my cruiser. After the list it was definately alot higher after getting rid of the 20 Y/O suspension, but the lean was still there. Why the lean and how do I fix it.
87 FJ60
The Dakar lift? Mine leaned until I swapped the right and left rear springs, now it is pretty much level.
I know....
I know you know how to use the search function....This topic has been discussed ad naseum.
How did you come up with your username?
The only reason I ask is that I used to be in a online gaming clan called Bad Karma
Bad Karma on the Harley lic plate, 510 where I used to live. Never used search function, but will look it up. Thanks.
If swapping left to right doesn't fix it, you might need to run two A or B springs. That's how mine panned out. ARB sent me a second A spring at no cost, after taking a few measurements for them.
