Cross Canada Adventures
Malmö, Sweden
As I’m sure some of you have heard I recently lost my mind and decided to move to Ottawa. Naturally I couldn’t leave my truck behind so elected to drive my sprung over, diesel converted, turbo’d 1975 FJ40 from Victoria to Ottawa. I decided to use the ferry this time as my previous water adventures didn’t turn out well. Hopefully you’ll be entertained by what follows… I know I was!
Day .5 and 1:
After packing up the trailer and getting ready to roll out I met up with my buddy Graham who would be traveling with me to Ottawa (He had gone crazy and wanted to purchase my nana’s 1989 Cummins turbo diesel to put into his 1976 ford). Cam had also come by the house for one last beer and to drop off my trailer hitch (needed something with a 15” drop which is a little hard to come by commercially). Lucky for me Cam was also heading to the mainland for his whipsaw adventure so we decided to catch the same ferry across.
Driving out of the driveway I heard a horrible screeching sound so I stopped at the first stop sign fired up the 4 way’s and climbed out to figure out what the problem was. Turns out the trailer that I had just purchased was a little loaded and the tires where rubbing on the fenders. We jacked up the trailer with the high lift and jumped on it until they were nicely bent out of the way. One last stop at lordco for zip ties and a new light and we would be on our way. Driving onto the highway from lordco I accelerated grinning like a little kid as the turbo kicked in and we went up through third shifting into fourth the engine fell flat on its face and the truck began to decelerate… we pulled off the highway and started to diagnose problems. The turbo return was clearly not big enough and the turbo required a rebuild so we worried that perhaps the oil blowing by and into the intake was causing some sort of issue. We decided it was high time we got on the mainland and limped the truck onto the ferry with plans to fix it on the ferry. We pulled out of the toll booth right as the announcement to return to your vehicles was sounding. On the ferry we found a flat spot on the fuel line where I’d had a pair of vice grips for too long while I had the fuel tank out. Sliced this out and problem was solved!
After a few parking lot beers somewhere in Langley Graham and I parted ways with Cam and headed for Vernon to stay at my friend’s house. A quick stop at the scale revealed the cruiser and trailer combination weighed a little over 5600 lbs. A large number of slow climbs up the cocahala later eyes glued to the pyro and we were in Vernon!
The next day we found out that oil was pooling someplace and creating huge smoke clouds when the engine first fired up in the morning… luckily they cleared fairly quick and we were able to continue for Calgary after a quick Walmart trip we were on our way to Calgary! One major accident in Sicamous where the guy in front of us decided to take a left turn into Timmies without looking and got T-boned and his ranger rolled onto its side. We kindly donated a folding camp chair gave our statements and where back on our way! A short stop at the top of rogers pass to take some pictures and we were back on our way.
On our way into Calgary we noticed the boost had stopped showing although the turbo was still spooling fine so we pulled over to check it out. Turns out the little rubber boost adaptor had halfway died so we cut it shorter put it back on and hose clamped it. Found our way to Grahams uncles place for the night with a list of things to fix and wandered out to find my friends for a drink.:beer:
Day 2:
Waking up the next morning I was thrilled to be offered a coffee with baileys by Grahams family … they really are top notch hosts! After a delicious breakfast we headed outside to sort out a few issues on the truck and trailer. A few blocks from grahams uncles house we’d heard a horrible sound every time the electric vacuum pump kicked in. Turns out it’d fallen off and was dangling around. A few zip ties and it was back on! The trailer had been built by a little old guy who did a great job of the welding.... but a not so great job of the thinking about overloading it. He’d used the 2 top bolts labeled “not for mounting” in the hitch and as a result the hitch was starting to bend. We drilled the holes in the tongue in the proper location and beat the hitch straight with a hammer for mounting. Also the trailer tires where rather low and required a good shot of air. After these issues where sorted out and the boost line was fixed again this time with duct tape we said our goodbyes and headed out to Strathmore.
Reaching Strathmore we noticed the trailer was fishtailing a lot and since both of us had little experience with trailers we figured we’d jack it up and try to find the problem. Immediately we noticed the wheel bearings where loose and so while I fixed the vacuum pump for a 2nd time (the zip ties didn’t hold it well and it vibrated loose quite easily) graham got to work with the highlift to tighten up the wheel bearings. After a couple hours in the gas station parking lot we were all fixed up, vacuum pump rewired (it’d eaten its own wiring) and trailer bearings tightened. We headed off down the highway for medicine hat now well behind schedule.
With the trailer fishtailing like crazy we stopped in medicine hat and found the tires where being chewed up beyond belief so a walmart stop was in order to get new smaller tires. After informing the kid working that he would put whatever tires I specified onto my trailer we got new tires and where back on the road.
After this it still fishtailed until we moved the weight around... not enough tongue weight ... lesson learned!
As we crossed into Saskatchewan we headed towards Regina and then decided that we could take a detour to see the town where corner gas was filmed. About half way down a 40 mile long dirt road we decided to camp for the night.
Oh I love it! Keep em' coming.
In detroit... wifi sucks.... more pictures when i find good wifi!
Day 3
The next morning we found that the starter was out of commission so we had it all apart when this dodge cummins 4x4 wanders down the road so he kindly stopped and offered to pull the cruiser for a pull start. As the cruiser bumped along behind him on the dirt road the lawn mower fell out of the back of the truck. So Graham stood on the brakes and even on the dirt road we got to see how well the disk brakes worked when he stalled the cummins. After another pull start we were good to go!
Heading off afterwards we were unable to shut the truck off as it was no longer start-able. We stopped at corner gas which was a little disappointing (they’d boarded up all the windows and replaced the pumps with wooden boxes that looked like pumps). Unfortunately I forgot grahams wheel chock in the parking lot of corner gas. So we headed on to regina stopping at the CAA office to enquire if they knew any cruiser guys who might have a spare starter.
We arrived at the CAA office about half an hour before it opened and the manager quickly welcomed us in and told us that his brother owned a few cruisers! Graham stayed with the idling landcruiser while me and the manager drove around town to all the cruiser guys he knew in search of a starter. Eventually we met a guy named Rob who said that a guy named Tom in Oak Lake might have a starter but he didn’t have his number. So off we went towards Manitoba.
Eventually arriving at Oak lake we enquired at the town’s only shop if they knew “a guy named Tom who drove a truck like that” supprisingly they did. Tom lived down the street over the tracks past the grove of trees. So we wandered down the road to Toms house finding him there. A great guy who had a 60 parked under some trees, a 40 on the back of his big rig, and an extended 40 troopy that he’d built and a 1940’s or so jeep on a cruiser chassis. He happily offered the starter that he had as a spare unfortunately it didn’t work either! So we decided with Ryans help that drilling a hole in the back of my starter to “manually plunge it” as the coil seemed dead was the way to deal with this. Tom helped us to weld up a little tool with a bolt and a piece of flat rod. Now we could turn the truck off again!
Pushing on we passed Winnipeg and continued up through the shield without stopping until we reached Thunder bay in the morning just in time for breakfast.
Still in detroit... wifi still sucks...
Day 4/5
Thunder bay greeted us with breakfast and coffee at timmies which after a night of not stopping was very welcome. We stopped in the parking lot to chat with the local version of “Cletus from the simpsons” who was very clever and explained how he’d done many spring overs and did I get mine from the internets. Asking many questions about the truck he was quick to explain how he’d done tones of those… then ask an elementary question.
We continued on and drove all day and pushed through Sault-St-Marie eventualy stopping when it started pouring rain in the dark and the wipers wouldn’t work. Not to let this stop us we ran a wire from the fuse panel out the kick vent directly to the wipers and hotwired them so we could get back on the road. The rain-x on a flat windshield just didn’t cut it!
Driving through the night again we eventually found a Timmies with breakfast and coffee so we pressed on. About 20 min outside of north bay we were both falling asleep and decided that we would pull off the road and have a nap. Waking up the truck refused to start. Not even a bit of a spin from the starter. Looking at our map we determined that our position was about 340 km from my nana’s house so we hailed a tow via BCAA and got towed to my nanas. Cost $20 over my BCAA coverage… cheaper than the gas!
Day 4/5
Hey now, I was born in Thunder Bay! That is likely one of my relatives :hillbilly:
So is the theme of this story going to be "I thought a Landcruiser was supposed to be reliable?" :hhmm:
landcruiser got to ottawa...
so this was the shakedown run... things done and untested this year:
spring over(river test only)
diesel swap
5speed swap
hard top (ok this can't really go that wrong short of falling off)
bought trailer
welded in trailer hitch
turbo
not bad for a shakedown run... 4500 km including 35 degree + weather across the praries and big ass hills in bc !
here are my pictures from the drive. it was quite the journey, im not gonna lie i've never been so happy to get a 5 hour ride in a tow truck. i think the cruiser did pretty good however, a lot of the problems were to do with that crappy vaccume pump, and the trailer.
and steve forgot to mention that we managed to find possibly the only hill in saskachewan to roll start off of:D
here are the cruisers just before we went on our way, note hood up
a crappy quality pic that shows how much stuff was crammed into the 40
this is the accident in sicamoose, the ranger had started to catch fire at this point. both people seemed to be okay when we left
"jack" the fish also survived the journey
random shadow pic in manitoba
F@$%ing bugs!
By saskachewan be were rolling good, doors off and stereo fixed
Well over 30 hours straight driving since Regina, at lake superior
This is as far as andy made it, 349km away from the destination and the starter finally got the best of us.
tow truck arives
and this is what i brought back, Rusty old cummins that runs great! felt like luxury after the cruiser, and made it home with only blowing the turn signal flasher. besideds having no floor and a roof that was trying to fly off
Greasemobile to to the max! With such nice weather you should have just finished the job and made er' a convertible Dodge, or would that have affected cab integrity??:hhmm:
Looks like you had a good trip...:D
Random quote:
"How'd you get here" (Specter front counter person)
"Drove" (me)
"Not yer 40" (Specter)
"Yep" (me) :D
"How ye getting back?" (Specter)
"Drive" (me)
I sure as heck wasn't going to leave it there. It took me from LA to Pheonix to Victoria... and is still taking me places... 12 years later with no major work.:D
Hijack over.
My nana drove that thing for a few years with the roof duct taped down... you couldn't tape it good enough to hold it on for a whole week? :flipoff2::steer:
I just can't not chuckle when you say "nana".
Your folks must be out of town ( or ignoring me lol) so I'll try again next week , going camping this weekend...:beer:
