No. In theory, a triple locked vehicle has 100% of power going to each wheel at same time. Not 25%.If the axle is locked and each tire spins at precisely the same speed, do they not each receive the same amount of engine output? Wouldn’t that mean a triple locked vehicle only sends 25% of power to each wheel?
and, vice versa, if you limit traction on ALL wheels except 2, on a center locked vehicle, then 50% of of that energy goes to each of the tree spinning tires? This is the situation most people that get stuck in standard 4wd’s have. They are sending 50% of the energy to one of their front tires that has no traction...and 50% of the energy from one of the rear tires that has no traction.
so if you can use your crawl control system to, essentially, arrest all spin on various tires on the front and back as needed, you increase the energy going to a particular tire at a rate of 50%, similar to how a stuck vehicle spinning a tire on the front and back would be...except with crawl control, due to braking, you are just swapping that 50% away from the tire with no traction and to the tire with traction.
im not an engineer, btw, hence the request for discussion/dialogue.
If you turn a pencil on one end, then does the other side get turn too? the other side gets 100% of torque you applied, right? Same principle. Because it is locked at 3 points, all engine torque flow continuously To each corner…and all corners get 100% (in theory) torque.
