g'day punters; i am seeking a little information from you knowledgeable mudders regarding crankshafts and harmonic balancers.
my old 64 fj45 (project patina) is recieving a bit of love of late; i been actually considering starting a thread about her sometime. anyways we're in motor rebuild mode now and starting to turn our nose up a little at the crank; it needs an undersize and has suffered abuse where the h. bal. located. the h. bal. is also cracked at the crank points (from either wild eyed excessive cranking or more probably misuse during a reinstall) and needs replacing.
so i dug 2 old cranks from the very depths of my fathers junk shed and noticed they are different. one is cast 'TEQ' (on the counterweight) and has a smaller h. bal. keyway. the other (later?) is cast 'T' and with a larger h. bal. keyway. when the change? anyone know how to decode the other markings on the crank? am i right that fj25 have a very simple front pulley arrangement?
the motor i have pulled down has the 'T' cast crank and a block casting date from 1965. not necessary original crank though; this motor has been apart before.
also, anyone got hints for reinstall h. bal. apart from flog it on with a soft hammer?
thanks all
thanks all
