Looking for advice on a catch system for the crank case breather on my turboed 1HZ. It has to be disconnected from the intake or the turbo will pressurize the block, or at least not allow pressure to vent if you added a PCV valve.
Currently I run a hose down behind the RH side tire venting to atmosphere like the 3B used to... I would love to install some kind of catch system, but have heard issues with backpressure that negatively affects the engine.
I also know that some will route that hose pre turbo but I did not want to introduce oil vapor into the intake as I want to be able to check the intake for oil to check the health of the turbo.
I am not getting any real blowby, but there is still a little oil drip now and again after longer trips or highway driving.
Thanks!
P.s. I did search, but wondering if any new solutions had been discovered.
Thanks!
