With the engine lubrication system being one if not the most important system on your engine, my thought all along has been not to mess with it. From putting in an adaptor and using screw on filters to relocating the filter using some aftermarket deal to changing the housing from plastic to aluminum.
Happy AMD aka The Car Care Nut is shining some light on this.
You indeed have to think for a moment why Toyota Japan would deliver the Land Cruiser with the plastic cartridge as it is, given reliability is priority. Beside the points mentioned by AMD, the plastic housing has an advantage over the aluminum part. It prevents any thread or seal damage to the female receiving part on the engine.
The only thing I will look for once I start changing my own oil (for now doing at Toyota being in the initial warranty period, just for simplicity in case an infant issue arises) is a tool like this to prevent damage removing and installing the filter housing. And not screw it on with excessive torque (25Nm or 18ftlbs).
In addition:
- Buy OEM filter cartridges at the local Toyota dealer ship
- Probably get 0W-30 or 5W-30 full synthetic, since the 0W-20 seems a US regulatory thing instead of what is used globally on the 3UR-FE
From non US manuals:
